1997 Isuzu Rodeo Dies While Driving
1997 ISUZU
BOBM
I was driving my Rodeo yesterday and it kept dying while I was driving. First time the dash lights lit up and the car just stopped. I turned the car off and started it again and it fired right up.
Later that day the dash lights came on and it seemed like it was going to shut off again but it fired itself back up again. This happened twice. So far it did not happen on my drive to work.
Someone told me it might be the fuel filter? Any ideas? Where is the fuel filter on a 97 rodeo?
Jan 12, 2007 at 3:40 AM
SERVICE WRITER
  • 9,123 POSTS
Have the electrical charging system checked, Bad alternator?
Jan 12, 2007 at 9:30 AM
BOBM
Had alternator replaced about 4 months ago. When that went bad my air con stopped working and my check engine light came on. i put fuel system cleaner in my gas tank this weekend and it hasn't happened again. It actually only happened those 2 times a couple weeks ago and then a couple days ago. I also started warming up my car a little longer in the morning. Is it necessary to warm up older cars?
Jan 15, 2007 at 12:47 AM
SERVICE WRITER
  • 9,123 POSTS
Not a bad idea to let it warm up a few minutes, I can't really say I do. Reman or rebuilt alternaters seem to have a higher tendencies of failure than may other parts. You still may have one that is a borderline one even though it's 4 months old. I'm more apt to think the fuel inection cleaner and problem occurance are not related.
Jan 15, 2007 at 1:56 AM
BOBM
Thank you for all your help
Jan 16, 2007 at 12:31 AM
Suggested Repair
Have the electrical charging system tested. A remanufactured alternator replaced only four months ago can still be borderline and cause the engine to die while driving.
Conversation Summary
The owner of a 1997 Isuzu Rodeo said the engine died while driving as the dash lights came on, then restarted, and nearly stalled again later. Someone else suggested the fuel filter. The expert recommended checking the charging system for a bad alternator. The owner noted the alternator was replaced four months earlier, added fuel-system cleaner, and asked about warming up older cars. The expert said a short warm-up is reasonable but not essential, noted remanufactured alternators fail more often, and doubted the cleaner was related.
