1999 Isuzu Rodeo Fuel in Oil
ISUZU
JDIAZ
Isuzu Rodeo 1999, 97,000 miles, V-6 3.2 L, manual transmission 4 x 2. Since new I always used Mobil 1 synthetic oil. About 7,000 miles ago switched to Penzoil synthetic oil. It might be a coincidence but i noticed a reduction in the oil consumption (it was using 1 qt. every 1,900 miles approx.). Since 5,000 miles ago it is not consuming any oil at all, actually the oil evel is increasing approximately 1 qt. every 1,000 miles and it is loosing its viscosity. All the other engine fluids stay at their normal level. I suspect fuel (gas) is somehow getting into the oil. The engine check light is on, but the codes are one for the heater sensor and the other, i believe, is for the EGR valve (P1404). Engine starts and runs normal. I will appreciate your help. Thanks
Jul 26, 2007 at 3:16 PM
2CARPRO JACK
  • 11,533 POSTS
The only place I can think of that fuel will get into the oil is from a blown fuel pressure regulator. Should be on th efuel rail with a vacuum line to the intake, remove it and check for raw fuel in the hose
Jul 27, 2007 at 1:01 AM
JDIAZ
Hi, thanks for your prompt reply. There is a diaphragm conected to the aft. l.h. side of the rail. I checked for presence of fuel but there is none, it smells like gas though.
Is it possible to leak fuel from the fuel injectors when the engine is sutdown and the rail stays pressurized? Thanks again.
[quote:b0e9df6a2d="2CarPro Jack"]The only place I can think of that fuel will get into the oil is from a blown fuel pressure regulator. Should be on th efuel rail with a vacuum line to the intake, remove it and check for raw fuel in the hose[/quote:b0e9df6a2d]
Jul 28, 2007 at 3:53 AM
2CARPRO JACK
  • 11,533 POSTS
That is possible, but usually that willl cause rough running in the am and excessive long cranking to start in the am
Jul 30, 2007 at 12:40 AM
JDIAZ
After running the engine a few times, found gas in the vacuum side of the pressure regulator. Thanks for your help.
[quote:c6c989101a="2CarPro Jack"]That is possible, but usually that willl cause rough running in the am and excessive long cranking to start in the am[/quote:c6c989101a]
Aug 2, 2007 at 2:16 PM
Suggested Repair
Replace the fuel pressure regulator. Fuel found in the vacuum hose on the regulator indicates a ruptured diaphragm, which can let fuel enter the intake and dilute the engine oil.
Conversation Summary
A 1999 Isuzu Rodeo with a 3.2L V6 began gaining oil and losing viscosity after an oil-brand change, suggesting fuel contamination. Other fluid levels were normal, and the engine ran normally despite a heater-sensor code and P1404. The expert advised checking the fuel-rail pressure regulator vacuum hose for raw fuel. The owner later found gasoline on the vacuum side of the regulator, confirming a failed regulator.
