Hi, just giving you an update. I just tried to put AC Pro Stop Leak Super Seal but don't think anything even came out of that cannister, I added more R-134a with leak sealer and ran the truck for 20 minutes. With everything on I got a little more than 20 psi reading and with everything off I got a 45 PSI reading. 77 degrees outside. My plan is to return the Ac pro stop leak super sealer and try the super tech version and go from there. I'll worry more about finding the leak after keeping track of the psi over the next couple of weeks.
I also have a 99 Corolla that will probably need a radiator replacement soon. In looking for a radiator for it, my question is does it matter if the radiator is set up for automatic transmissions or not. All I seem to find is radiators that have 2 connections for automatic transmissions at the very bottom. My assumption is that will work, I just don't connect anything to those two ports, but my fear is the dimensions might be different and somehow not properly fit my manual transmission, Corolla.
Thanks for all your help.
Tuesday, November 29th, 2022 AT 11:03 AM
