I had ac compressor put in about 2 months ago. For some reason it stopped working. I can't hear the clutch engaging when I turn it on.
Dec 19, 2007 at 1:56 PM
✓Experienced Mechanic
Hi there,
You may have an electrical problem (fuse) or the system is low on refrigerant and the low pressure switch has cut in and shut down the system. You will have to get the pressures tested to see if it has lost refrigerant, Do this first.
Mark(mhpautos)
Dec 19, 2007 at 3:51 PM
