a/c clutch
168,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
JASONPYZO
  • 87 POSTS
was wondering if they have a tool to fix the threads of the A/C clutch. I cannot thread the tool in to get the A/C clutch off.
May 14, 2017 at 4:45 AM
HMAC300
  • 48,601 POSTS
it may be a metric thread and if you are using US thread it will not work. check that first.
May 14, 2017 at 5:49 AM
JASONPYZO
  • 87 POSTS
no it is the right one , I checked that first. The threads in the clutch are messed up, but even if I had the right tap it would not work because of the shaft from the compressor. so I was wondering if they had a special tap, tool or thread chaser that would clean up the threads?
May 14, 2017 at 6:46 AM
HMAC300
  • 48,601 POSTS
not really a special tool, there is a different puller for older vehicles that goes where the belt goes. do not know what to tell you on this one as there is not anything I can think of unless you use a puller more designed for rear end bearings but hard telling what that would do as far as breakage and compressor would need to come off for that one.
May 14, 2017 at 8:50 AM
JASONPYZO
  • 87 POSTS
alright man thanks.
May 14, 2017 at 12:35 PM
