1993 Honda Civic Speedometer Failure
JIMHENNI
The speedometer has been working off and on (now mostly not working) as well as the odometer just stopped working. Could the problem be with the cable? If so how do I locate the cable to check for corrosion.
Thanks
Apr 13, 2007 at 5:27 PM
  • 75,988 POSTS
[quote:ea6ac44143="jimhenni"]I have a 1993 Honda Civic dx, 157000 miles. The speedometer has been working off and on (now mostly not working) as well as the odometer just stopped working. Could the problem be with the cable?
Thanks[/quote:ea6ac44143]
I think! instead of looking for a cable , you'll be looking for the VSS Vehicle Speed Sensor at the transmission-take it out, key in On position, spin the the sensor the speedo should fluctuate then come back
Apr 7, 2021 at 6:09 AM
Suggested Repair
Check the vehicle speed sensor (VSS) at the transmission rather than a speedometer cable. Remove the sensor, turn the key to On, and spin the sensor; the speedometer should fluctuate and then return.
Conversation Summary
The owner of a 1993 Honda Civic reported an intermittent speedometer that now mostly does not work and an odometer that has stopped. They asked whether a corroded cable could be the cause and how to locate it. The expert advised checking the vehicle speed sensor at the transmission by removing it, turning the key on, and spinning the sensor to see if the speedometer responds.
