1990 Honda Civic Speedometer Not Working
WISHES
Ok let me start I have a 1990 4dr "Lx"? i believe Civic i just got it awhile ago and been slowly fixing it (new exaust new windshield new tires etc etc etc..) well i have a little problem my speedometer doesnt work the car alarm on it doesn't work and the heater doesnt work! Lol so when i go to get things fixed the windows fog up I freeze Yeah. i was told it's most likely a fuse or just a couple thingss got un-hooked i was also told when the person before me put in the new deck they might have messed up some wires. Any help would be helpful!!! Thank you! ~Alex
Nov 7, 2006 at 12:54 PM
BRUCE HUNT
  • 3,754 POSTS
Check all of the fuses and look at fuses under the hood of the car. If the tach works but speedometer doesn't you need to replace the speedometer. Fan doesn't blow on the heater or the fan blows but no heat?
Nov 8, 2006 at 2:06 AM
Suggested Repair
Check all fuses, including those under the hood. If the tachometer works but the speedometer does not, replace the speedometer. For the heater, determine whether the blower does not run or runs without heat, and inspect wiring that may have been disturbed during the stereo installation.
Conversation Summary
The owner of a 1990 Honda Civic reports that the speedometer, alarm, and heater do not work, and suspects a fuse, disconnected wiring, or damage from a previous stereo install. The expert advises checking all fuses, including under-hood fuses, replacing the speedometer if the tach works but the speedometer does not, and clarifying whether the heater fan fails to blow or blows without heat.
