1994 Honda Civic Speedometer Not Working
ALEJANDROJL21
i have a 94' honda civic EX and i just received it as a gift from my brother, when he bought the car, the speedometer and odometer didnt work and he never repaired them. I on the other hand, actually wanna kno how many miles im putting into the car and how fast im going. i've asked in several forums and havent gotten an answer. Can anyone please help me?
Oct 15, 2006 at 2:29 AM
BRUCE HUNT
  • 3,754 POSTS
If the tach works the speedometer itself is bad. You can get a used one pretty cheap from the online junk yards. I have purchased them for as little as $15.
Oct 17, 2006 at 1:26 AM
HONDAGUY81
Go to auto zone and pick up a VSS. Vehicle speed sensor. it is a common problem with F series engines. If the speedo only works once in a while, or flickers, That is the problem. It is a painless fix.
Nov 3, 2006 at 10:19 AM
Suggested Repair
If the tachometer works, replace the faulty speedometer with a used unit from a salvage yard.
Conversation Summary
The owner of a 1994 Honda Civic EX says the speedometer and odometer have never worked and wants them repaired. An expert says that if the tachometer works, the speedometer itself is bad and a used replacement can be inexpensive. Another reply suggests checking the vehicle speed sensor if the speedometer works only intermittently or flickers.
