1995 Honda Civic Speedometer Fails
CFISHER69
One problem though, every so often, the speedometer, odometer, and trip meter all go out (basically center unit of the console). The needle will jump up and down for a second or so and then drop to 0 even on the highway. Eventually it comes back on (either within a minute or so and once or twice it has stayed off for 40 miles). I've witnessed this happening both when hitting a bump and when not hitting a bump so it may not be a loose wire. Any thoughts as to what might be causing this and how I could get it fixed for cheap?
Jul 13, 2007 at 6:03 AM
BRUCE HUNT
  • 3,754 POSTS
Likely the answer is the VSS sensor on the tranny. During the times when it is working right you can get a reading using a volt-ohm meter. During the time when it is not, pull over and check the readings again. If they are the same replace the cluster or check for bad connections. Readings are different replace the VSS.
Apr 7, 2021 at 6:05 AM
Suggested Repair
Compare volt-ohm meter readings at the vehicle speed sensor (VSS) on the transmission while the gauges work and while they fail. If the readings differ, replace the VSS. If they stay the same, check for bad connections or replace the instrument cluster.
Conversation Summary
The owner of a 1995 Honda Civic DX reports that the speedometer, odometer, and trip meter intermittently drop out, with the needle jumping and then falling to zero before returning. This occurs both after bumps and without them. The expert says the transmission VSS is the likely cause and recommends comparing meter readings during normal and failed operation to decide whether to replace the VSS, repair connections, or replace the cluster.
