1998 Honda Civic Speedometer Stuck
RAQ
I currently Drive a 1998 Honda Civic DX; 154,000 miles; Stick shift; 2 wheel. I was driving to work this morning and noticed that the speedometer was stuck at 20mph, and is still stuck there. It won't move up nor down...was working perfectly yesterday. Any troubleshooting ideas? Thanks.
Sep 24, 2007 at 7:52 AM
  • 75,988 POSTS
[quote:3eaa25011b="Raq"]I currently Drive a 1998 Honda Civic DX; 154,000 miles; Stick shift; 2 wheel. I was driving to work this morning and noticed that the speedometer was stuck at 20mph, and is still stuck there. It won't move up nor down...was working perfectly yesterday. Any troubleshooting ideas? Thanks.[/quote:3eaa25011b]
Could be the speedometer itself, go find the VSS remove it turn key to On-spin the sensor is the needle fluctuating or still stuck.
Sep 24, 2007 at 10:48 PM
Suggested Repair
The speedometer itself may be at fault. Locate and remove the vehicle speed sensor (VSS), turn the key to On, and spin the sensor. If the needle still does not move, the speedometer is likely stuck.
Conversation Summary
The owner of a 1998 Honda Civic DX with 154,000 miles reported the speedometer stuck at 20 mph after working normally the day before. The expert suggested the speedometer may be faulty and recommended removing the VSS, turning the key to On, and spinning the sensor to see whether the needle fluctuates or stays stuck.
