Turn signal turns not working?
BLUELIGHTNIN6
  • 16,542 POSTS
Not sure exactly what "freak out" means but you may want to ensure the ground wiring and other connectors are tight and connected properly at the switch you worked on.
Tuesday, May 26th, 2020 AT 12:01 PM (Merged)
BEASLEY2013
  • 5 POSTS
  • 1988 HONDA CIVIC
  • 385,000 MILES
Tried to fix problem with LH signal flashing when RH engaged. Blew a fuse when I shorted LH switch to grd. Now only have LH signal, none on RH. Flasher works, also the Em. Flasher works for all lights, including RH, but no turn signal to RH side. Continuity checks OK for turn switch in all positions. Voltage at Em. Flasher is @ 13V, but signal switch shows @ 8V.
Suggestions?
Tuesday, May 26th, 2020 AT 12:02 PM (Merged)
KHLOW2008
  • 41,814 POSTS
The left signal working does not necessarily mean the flasher is good. Left and right have different circuits within. Do all the lights turn on when the hazard lights are turned on?
BEASLEY2013
  • 5 POSTS
Yes, all lights work perfectly when Em. Flasher on! I rechecked the posts on switch & found I had bent one during testing & now have all working, except as before - the LH sidemarker blinks when RH is engaged. I took the flasher & swapped into another Honda, it is fine! To pass inspection, I removed wiring for the side markers & just use as an ornament, but would rather fix the problem & have sidemarkers as turn indicators.
BEASLEY2013
  • 5 POSTS
Also figured out that the main Volt. Comes from Em. Flasher switch & the turn sig. Switch will only have 7-8V. Just puzzled in what I'm missing!
KHLOW2008
  • 41,814 POSTS
I am confused with the situation and let us put it in proper perspective so that I under the problem correctly.
1. LH signal flashes when RH is turned on. This is to mean the signal switch only works the LH when when it it turned to right or left? If yes, you could have a bad siwtch.
2. Less than battery voltage can mean a poor connection somewhere and for the flasher relay, the correct voltage is important fo it to work correctly.
I tried checking through the circuit schematics in our database and is as confused as before. Not easy when there are 3 diagrams to link. Maybe I should try printing them out to check.
BEASLEY2013
  • 5 POSTS
The LH sidemarker blinks when RH turned on. The LH turn signal (in bumper) doesn't blink when RH on. RH side works normally. All lights blink as expected on Em. Flash. Have tried another switch from working Honda Civic as well as flasher relay. Same results. The LH will blink normally when LH on, but LH sidemarker also blinks as the RH blinks.
KHLOW2008
  • 41,814 POSTS
There are 2 relays in the circuit. You mentioned swapping, was both swapped or only the hazard flasher? In the underdash fusebox there is another side marker flasher relay.
BEASLEY2013
  • 5 POSTS
Swapped turn signal relay, not the other relay!
KHLOW2008
  • 41,814 POSTS
Check out the side marker relay. Seems that is the only component that can cause the symptoms described.
