Turn signal turns not working?
HAMMPAMELA
  • 1995 HONDA CIVIC
  • 4 CYL
  • MANUAL
  • 165,000 MILES
I have no instrument readings on my dash which
includes speedometer, turn signals do not work,
fuel gage reading and illumination. Changed
fuses several times to no avail. Manual does not
help me.
Tuesday, May 26th, 2020 AT 12:00 PM (Merged)
F4I_GUY
  • 3,302 POSTS
You may have a faulty cluster or a connection at the back may be loose or unplugged.
Pull out the cluster and ensure the wiring is good and that you are recieving all the proper power/grounds and signals. If you are, replace the cluster.
BROHAM03
  • 1992 HONDA CIVIC
  • 4 CYL
  • MANUAL
  • 80,000 MILES
My buddy was working on my car, he was putting in a kill switch. Some how along the way, we had to remove the drivers side fender, as well as the corner light, in doing so the wires came off so I hooked them bach up wrong I think, the hazards and turn signals dont work now, would it be a blown fuse? They all looked good, unless I missed one. Another question, is it possible for the turn signals and hazards to function without the flasher relay? My car doesnt have the flasher relay where its suppossed to be. But they have always worked before, is it possible its placed in a different location? My blinkers used to blink rapidly, so I know they altered it somehow. Please help, thanks!
KHLOW2008
  • 41,814 POSTS
Hi Broham03,
Check the hazard switch connectors. If the hazard switch is not connected, the hazard and turn signals would not work.
A blown bulb would cause the turn signals to work fast. Ensure all bulbs are working.
BRITTANYPHILLIPS4
  • 1992 HONDA CIVIC
  • 4 CYL
  • FWD
  • 190,000 MILES
When I put my left or right blinker on, my four ways come on therefore I have no turning signals. The guys at O'Reily's have checked the fuses and bulbs. When I have my lights on (at night I can really notice this) the lights on the speedometer part don't come on but the heater/ac panel lights come on and they blink with the signals (four ways) if I actually try to use them. What could be the problem?
If this helps, the person that had the car before me had a system in there and took it out before they traded it in, Could they have crossed some wires or something?
KHLOW2008
  • 41,814 POSTS
Hi brittanyphillips4,
Seems some wires had been crossed or you have a faulty flasher unit.
The speedometer illumination light bulb should be bad and requires replacement.
There is a possibility some ground connections are not securely tightened resulting in the AC heater panel lights flashing in tandem with the flasher.
JMC4120
  • 1998 HONDA CIVIC
I have a 98 civic and the other day I noticed that the driver side blinker was not working, the passenger side works fine. On the dash the D/S blinker flashes really fast as does the rear blinker light. I have checked all fuses and bulbs they all check out fine. When I turn the flashers on they all work except for the driver side. It has been very frustrating to say the least. Any help with this matter would be greatly appreciated.
Tuesday, May 26th, 2020 AT 12:01 PM (Merged)
FIXITMR
  • 9,990 POSTS
This is because you have a front blinker light out which causes the blinker to go fast on the side the bulb is out.
Cheers
JMC4120
Yep worked like a charm, thanks!
SYRON
  • 1998 HONDA CIVIC
Hello, I recently had 1 dim headlight and went to Autozone they said it was a bad ground probably also came to the same conclusion after searching over many websites I found the ground wire its on right front it connects to frame and I cleaned it until it was shiny now my headlight is full and bright again (yay) but my blinker is still dim. Both tail lights in the back are fine. When I use the blinker in the car sometimes it blinks really fast or really slow but it is still dim. I was wondering if there is a ground for the blinker that I need to clean as well? Any advice would be helpful. Thank you for your time.
SERVICE WRITER
  • 9,123 POSTS
When the signals are blinking really fast, get out and check to see what light is out. There is probably a bad filiment. There are grounds at the sockets that may be causing the dimness.
SYRON
When it blinks fast/slow it changes every now and then. I went and looked at the light and its blinking but not illuminating the area around the light its more like a Christmas light. It doesn't seem reflect and be bright enough to go outside of the light casing for other cars to see.
SERVICE WRITER
  • 9,123 POSTS
Have you tried a bulb (s) at all?
SYRON
I replaced the front bulb, on the headlight, but not the blinker bulb. I couldn't figure out how to remove it. Do I have to remove the whole headlight?
DARIN-A
  • 1993 HONDA CIVIC
  • 4 CYL
  • FWD
  • MANUAL
  • 207,749 MILES
I have a 93 honda civic 2 door coupe ex and my left turn signal flashes faster than the right. The hazard lights work fine, I`ve tried bulbs, a flasher, turn signal switch. I`ve checked the grounds at the front and rear sockets with a test light and seem ok.
What do I do now? Any help would be greatly appreciated.
SERVICE WRITER
  • 9,123 POSTS
Without seeing it. It makes it pretty tough. Each manufacturere has their own way of messing with our heads. Some hondas call for the bumpers to be removed :shock:
IF you want to post several pics, we can try to determine it if you like.
KHLOW2008
  • 41,814 POSTS
Hi darin-a,
If the speed difference is not much, then it should be the bulb ratings are different or a faulty flasher relay. If it is ver fast, then 1 bulb on left side should be faulty and not working.
DU
  • HONDA CIVIC
I have a 1997 Civic Honda DX coupe. The other day, I have had problems with my left turn signal blinkiing faster than the right signal. I went to an Auto parts store and they said it was my flasher and sold me the part. The left turn lights both front and back still work. Did I get the right part and if so, where is the flasher located? Thanks.
Check your bulbs and sockets for that side
Location: behind left side of dash tape to the wire harness.
CNANNERS22
  • 1993 HONDA CIVIC
Electrical problem
1993 Honda Civic 6 cyl Two Wheel Drive Manual
I just recently changed out my headlight switch & now when I try to use my blinkers my interior & exterior lights freak out?
