How to Repair Automotive Turn Signal Problems
Turn signals are intended to help inform surrounding drivers of the vehicle's intended change in direction. Although there are a few different causes for signal failure, directional light problems will commonly affect individual bulbs, one side of the system, either right or left, or a complete breakdown leaving the turn signals non operational.
What Goes Wrong?
As with any lighting system, heat and corrosion can cause issues over time. Bulbs can be burnt out, flashers, BCM's, or lighting control modules can fail, or there can be connection issues brought on by damaged or corroded connectors or wiring failures.
What Does it Cost?
Lighting issues repairs can range from the simple to the complex. A simple bulb or flasher replacement is inexpensive while a BCM or lighting control module can cost several hundreds of dollars. In addition to parts, troubleshooting the issue must be considered in the labor charge.
Let's Jump In!
We will start with a single bulb that is not working, then one side not working, and finally to an entirely inoperative system. To begin, turn the ignition switch on and activate the signals to identify the issue.
Single Bulb Failure - This is the easiest of the turn indicator problems to repair. First, access the bulb by either removing the lens or gaining access to the bulb from behind. Next, remove the turn signal bulb to replace it with a new unit and reassemble.
turn signal bulb replacement
One Side Failure - With the ignition key still on, use a test light to check for power and to test the blinker system fuse integrity. There can be more than one fuse that runs the system. Most times, the fuses will have an ID which can be found on the fuse panel cover or BCM. If you are having trouble finding the fuses, please ask one of the 2CarPros community to help (free).
blown fuse
On older vehicles without a BCM or lighting control module, a turn signal flasher is used and can be configured to operate each side of the blinker system individually. When a flasher fails, it can prevent the system from lighting up or the lights to illuminate but not blink. The location of this flasher will vary. In the example below, it is located in the under hood fuse panel or PDC. Once located, remove the flasher to replace it with a new unit and recheck the signal operation. Again, if you cannot find the flasher unit please ask one of our experts for help (free).
turn signal flasher
One Side (continued) and Total System Failure - A turn signal switch is designed to facilitate the operation for one side or the other. One or both sides can go bad. To test this switch, you must gain access to the rear of the switch or the switch wiring harness to check for output power to the particular side that is not working. Using a wiring diagram, which can be obtained by one of the 2CarPros community or a source such as AllData DIY, (pay) you can identify the wire color to test and check for power output using a test light. This will isolate the switch as the problem if no output power is present or a power supply to the switch.
turn signal switch
Depending on the manufacturer, a vehicle will have a BCM (body control module), TIPM (totally integrated power module) or LCM (lighting control module) which are designed to take the place of the turn signal flasher. If all fuses, bulbs, and connections are good, (including grounds), suspect one of these units is malfunctioning. To confirm a module issue, a CAN scan should be performed.
Questions?
If you have a car repair question, you can ask the 2CarPros community for help. We hope this guide helped you understand the repair. Please visit our 2CarPros YouTube channel for more helpful repair videos.
Repair Safety Notice: This guide is provided for general informational and educational purposes only. Vehicle repairs can involve risk of injury, property damage, or vehicle damage. Always follow proper safety procedures, use the correct tools, support the vehicle securely when raised, and consult a qualified automotive repair professional if you are unsure about any step.
