A MAF problem can cause the O2 sensor to trigger a trouble code or vice versa.
What were the exact codes?
Did you test the fuel pressure? Get a leak donew test done as well.
The fuel filter is a non serviceable item located in fuel tank but it sometimes leaks internally and this would cause fuel pressure drops.
If the filter is the cause, you would require prolonged cranking to start if the engine had been left standing for a while.
SPONSORED LINKS
helpful?Yes
Thursday, February 21st, 2019 AT 2:50 PM
(Merged)
