It shakes real bad when I accelerate, but when I let off the gas it is normal. It vibrates when I'm at a red light
Tuesday, December 29th, 2015 AT 9:02 AM
HMAC300
MECHANIC
Scan for codes it may be a misfire in engine
SPONSORED LINKS
Tuesday, December 29th, 2015 AT 9:42 AM
DEANNA77
MEMBER
I was hoping you could be more specific before I get codes. That's kind of my point in asking.
Tuesday, December 29th, 2015 AT 12:34 PM
HMAC300
MECHANIC
Unfortunately with todays cars from your question is what sounds like a misfire. Auto parts can do for free to find out exactly if a code. The only other thing you can do is to check for vacuum lines off/broken/cracked etc. Or maybe something obvious by running car and seeing spark jump from a wire off maybe or a broken wire.
