Engine cranks will not start?
DIYGUY71
  • 9 POSTS
Believe it or not, the car actually gets hotter after you shut it down because the WP is not circulating the antifreeze. I say this because a LONG time ago a friend was having a similar problem. Turned out as the car got hotter after he shut it down it expanded which caused a switch or sensor (I can't even remember which one) to create an open circut until the car cooled enough to contract and close the circut. I don't know if this helps, but it sure is interesting.
Saturday, October 3rd, 2020 AT 10:58 AM (Merged)
LEGITIMATE007
  • 5,121 POSTS
That can actually be true, and what usually is the problem is the engine coolant temp sensor. Have it checked, and remember, just because a sensor may be faulty, does not always cause a check engine light.
