I have a 2000 Honda Accord EX the problem I am having is that one of the cylinders will not fire at times.
Monday, December 17th, 2007 AT 5:24 PM
BLACKOP555
MECHANIC
How do you know it wont fire sometimes?
Did you get it scanned for codes and if so can you tell me what code it was such as a random misfire or a missfire on a single designated cylinder.
What do you mean it wont fire sometimes?
Post back.
SPONSORED LINKS
Monday, December 17th, 2007 AT 8:19 PM
TINKYNA
MEMBER
What I was trying to say is that when I start the car it runs fine. After driving for a few miles it starts to misfire on the cylinder that is greatest distance from the distributor cap.
Tuesday, December 18th, 2007 AT 12:04 AM
MECHANIC
Try inspecting the plug and make sure its gap properly, do a resistance check on that wire with an ohmmeter, if its over 30K's replace it.
Also consider the injector/compression on that cylinder.
You're getting a misfire-you should be getting an OBD2 code-between P0301 - P0304 its 4cyl. Or a random misfire P0300. Try getting it scanned for code/s and report back to B5
