Tuesday, January 3rd, 2017 AT 4:13 AM
I believe my fuel pump has gone bad, but to test it I was going to jump the relay to see if I could get it to work or not. But, I cannot find the diagram online for what wire is what on the relay. The car has been sitting parked for about five years it ran fine when I parked it though. But what is a long time for a car to sit without being started. The car will try to start with the external fuel pump I wired but the pump is too small so it is not getting enough gas. It will run for about three seconds and quit. So before I go trying to replace the fuel pump which I dread I want to make sure it is bad first.
