Is there voltage at the fuel pump fuse that goes to the relay?
Wednesday, October 21st, 2020 AT 6:20 PM
(Merged)
LEE M.
MEMBER
Yes there is voltage to the fuel pump fuse
(Merged)
CADIEMAN
MECHANIC
Check for power at the relay now from the wire from the fuse panel. With the relay is pluged in you should have power at pin 30 going to the pump.
(Merged)
LEE M.
MEMBER
Got power to the fuel pump now. Replaced the fuel pump with a new one. But now it won't start and the fuel pump does kick on. Cracks but no fire. What is your thought.
(Merged)
CADIEMAN
MECHANIC
Spray the throttle body does it start?
(Merged)
LEE M.
MEMBER
Did that and yes it does start for 3-5 seconds.
(Merged)
FIXITMR
MECHANIC
Is there a test port on fuel injection? Does fuel spurt out of it when opened? Do you have a way to pressure test? How did you get power to pump? `So you didn't test pump itself originally?
(Merged)
CADIEMAN
MECHANIC
We need fuel pressure. Also check the injecter fuses.
