1989 Chevy Camaro 6 cyl Manual
I am having trouble with my camaro, it turns on very well but the problem is when I step on the gas pedal. What happens is that the car kind of chokes and loses power. I have already replaced spark plug wires, fuel pump, ignition coil, fuel injectors, alternator, timing chain and sprockets, distributor cap and rotor, temperature sensor, water temp. Sensor, battery and terminals. I thought it would be the idle setting but when I checked under the hood the label read that the screw was factory set and adjustments should not be attempted. Please help.
Wednesday, October 22nd, 2008 AT 11:08 AM
