oh and thank you for the advice you gave me on my truck you nailed it right on the head for a proper repair :)
1989 Chevrolet Camaro IROC-Z Stalls
Okay, now we are having a problem with stalling and no-start condition on an Iroc? Are there any engine codes being stored? If not, and since you recently replaced the fuel pump, I am thinking the fault is related to the fuel system, specifically the new fuel pump. It is not uncommon for these to fail out of the box... Especially if not properly installed and primed. Did you replace your fuel filter when you did the pump? If not, and it was clogged, it may have caused the new pump premature wear.
Use a fuel pressure tester and check the fuel pressure under load (Parking Break, Wheel Chucks) and ease on the accelerator. If you can't reproduce the stall condition you may need to get creative and strap the pressure tester to the windshield with duct tape and watch it while taking it for a drive.
Suggested Repair
Check for stored trouble codes and test fuel pressure under load with a gauge, using the parking brake and wheel chocks or watching the gauge while driving. The replacement fuel pump may have failed early, especially because the main fuel filter was not replaced with the pump. Replace a restricted fuel filter if needed and confirm the pump primes and holds pressure.
Conversation Summary
A 1989 Chevrolet Camaro IROC-Z with a 305 TPI stalls after a few miles, then cranks but will not restart until it sits about 15 to 20 minutes. The fuel pump had been replaced about 2,000 miles earlier, but only the pump sock was changed, not the main fuel filter. An expert advised checking stored codes and testing fuel pressure under load, suspecting premature pump failure from a clogged filter or poor installation and priming. Other owners described the same hot stall and no-restart pattern and mentioned the coil, fuel pump relay, oil level, and injectors, but no repair was confirmed.
