1989 Chevy Camaro
89IROC
  • 1989 CHEVROLET CAMARO
1989 Chevy Camaro V8 Two Wheel Drive Automatic
hey I have an 89 iroc that I want to convert from fuel injection to carburetor, since I dont drive it much and it prbly won't pass emmission im going to put historical tags on it. Just wondering what is involved in this ive talked to some people and if heard ill have to change the fuel pump due to the pressure difference and ive heard that I might want to cut the computer out. What else would I need to do?
Thanks
Thursday, December 3rd, 2009 AT 7:04 PM
MICKEY-D
  • 304 POSTS
I don't think you should cut out any wiring until you do your swap, to see what works and does not work, and what trouble lights come on. Get an HEI distributor, and a decent intake and carb, and you should be ok. For the time being, just disconnect the wires to the ignition that's there, the injectors, and any sensors related to the stuff you don't want to use. Let me know how you make out, and good luck.
Mickey-d
Friday, December 4th, 2009 AT 10:26 PM
