ford tauras 1998 v6 270,000 kms
1998 FORD TAURUS
BARNEYGREENE2
my ignition switch is stuck in the locked position. it will not turn even if i turn the steering wheel slightly. nothing. its just locked and won't move
Oct 20, 2007 at 5:12 AM
BLACKOP555
  • 10,386 POSTS
your ignition switch seems like it is bad. try to put the ignition into drive and back into park may not be going into park fully. you can turn they key back to on if you want and take a little punch and push the little hole bellow the ignition to take out the ignition and check it out for wear. if it looks alright and they key isnt sloppy in it then the release isnt working when you put it in park.
Oct 20, 2007 at 5:51 AM
