95 Taurus transmission
PHARVEY123
  • 5 POSTS
My 1995 Ford Taurus GL 3.8L with 194568 miles, drove to daughters school in AM just fine, but when leaving will not shift from first gear into any other forward gear. Shifts reverse and back just fine, checked fluid OK, inspected all wires and cables to tranny all appeared connected and clean. Checked previous owner, the tranny was rebuilt before at un-known mileage. Please help with any suggestions.
Thank You
Sep 15, 2007 at 3:45 AM
2CARPRO JACK
  • 11,533 POSTS
Is the speedometer working? Have the PCM scanned to see if there are nay transmission codes
Sep 16, 2007 at 1:20 AM
ZUE
  • 76 POSTS
Is this a column shift? If so the bushings in the column could be worn and causing the shifter to be out of adjustment. I agree with the check of the PCM first. Some tranny shops will do a free PCM test to get your business.
Sep 16, 2007 at 2:03 AM
PHARVEY123
  • 5 POSTS
the speedo is working ok, I will have to fix my code scanner, I have not used since I owned my 84 little LTD, in response to Zue it is colmn shift butt feels solid and tried moving shifter while drivng to see if any change but none made it shift including manually taking it down to first and shifting up manually. Thanx
Sep 16, 2007 at 11:10 AM
