1999 Ford Taurus Brake Drum Stuck
THF05
I have tightened the adjuster wheel on the rear brake shoes to tight and cannot get the drum off. Is there an easy way to release the tension off of the brake shoes.
Sep 17, 2007 at 12:15 AM
SERVICE WRITER
  • 9,123 POSTS
IF the plug is still removed on the backing plate, use a flash light to see where the dog is that hold the adjuster wheel from turning. With a thin tool-screwdriver?, push it back and the use another screwdriver or brake adjusting tool to turn the wheel.
Sep 17, 2007 at 12:49 AM
Suggested Repair
With the backing-plate plug removed, use a flashlight to locate the adjuster lock. Push the lock back with a thin screwdriver, then turn the adjuster wheel with another screwdriver or a brake adjusting tool to release the shoes so the drum can come off.
Conversation Summary
The owner of a 1999 Ford Taurus tightened the rear brake adjuster too far and could not remove the drum. The expert advised looking through the backing-plate opening, pushing back the lock that holds the adjuster, and turning the wheel to release shoe tension.
