Brakes Lines Leaking
KINKEDSB
I have a 1997 Ford Taurus LX Wagon. I noticed the other day that the brake lines or what seemed to be the brake lines under the driver's side door was leaking. I took a look at it today and it didn't seem to me that there was anything wrong with them at all. Do you have any suggestions or ideas on what I should do, I would rather not take it in for repair if its just the brake lines leaking or a simple repair.
Thanks,
Ethan
Sep 12, 2007 at 5:25 AM
  • 31,937 POSTS
Hi there,
Best you follow the line to see where it goes, it may be a breather line. If it is a brake line, check the fluid level and have it checked by a qualified mechanic, if you have a problem with a brake line you are only putting your life and those also on the road at risk, you don't get a second chance with faulty brakes, I would put this in the most urgent list.
Mark (mhpautos)
Sep 12, 2007 at 10:27 AM
