Fair chance you'll need wheel cylinders, but need to look. There is a ridge that gets built up on the drum from the shoes wearing into the drum that I usually grind off before re-installing it, that may be the noise you hear as well.
After you slide the drum on and have the shoes adjusted, spin the drum and listen.
Tuesday, April 17th, 2007 AT 10:29 PM
