1992 Ford Taurus Rear Caliper Sticking
I didnot use the piston tool to push the piston inward i stuck the caliper and pads on is that y the caliper is sticking
Suggested Repair
The rear parking brake is built into the caliper and is not adjusted at the caliper. Retract the piston by rotating it with the rear-caliper piston tool on a 3/8 ratchet, not by pushing it with a C-clamp, which can damage the internal gears. Align the two piston notches at 12 and 6 o'clock so the pad pins fit. Adjust cable tension at the parking-brake adjuster under the driver's door beside the frame, and apply anti-seize. If the brake still will not release, inspect the cable and the new caliper piston.
Conversation Summary
The owner of a 1992 Ford Taurus with rear disc brakes replaced a rear caliper and was told to adjust the parking brake because the caliper was sticking. The expert explained that parking-brake adjustment is at the cable under the driver's door, not at the caliper, and that the piston must be rotated inward with the proper tool. The owner had used a C-clamp, which can damage the piston gears, then found the cable adjuster. The expert recommended the inexpensive piston tool and aligning the notches at 12 and 6 o'clock.
