1992 Ford Taurus how much will brakes cost me
AAAAAAAAAAA
  • 1992 FORD TAURUS
Brakes problem
1992 Ford Taurus 6 cyl Wheel Drive Type unknown Automatic 100000 miles
how much will brakes cost me to fix on this type of car and how much would a windsheild cost me
Monday, March 3rd, 2008 AT 3:17 PM
BLACKOP555
  • 10,371 POSTS
Brakes are aroudn 40 bucks per pad set *2 tires* for a decent pad set.
If the rotors are bad or need to be machined then that is about another 40 bucks per rotor.
Windshields are very variable dependent on the kind or the person installing, call aroudn for quotes.
Monday, March 3rd, 2008 AT 6:56 PM
HONDATECH1983
  • 109 POSTS
Depending on the quality of brake pads used I would say a general cost would be between $80-100 per end (either front or rear). If rotors need to be machined cost would go up another $80 or so. If rotors need to be replaced for some reason cost would go up between $60-$100.
Monday, January 2nd, 2017 AT 10:26 AM
