How to Replace a Brake Rear Wheel Cylinder
A brake system wheel cylinder is used to push against a set of brake shoes to help stop the car.
How Does it Work?
A brake system wheel cylinder is designed to receive hydraulic pressure from the brake master cylinder and transfer it to the rear brake shoes and drum, this helps stop the vehicle when the brake pedal is applied.
What Goes Wrong?
Filled with brake fluid the wheel cylinder is subject to heat and moisture. This can create rust inside the wheel cylinder which will cause the cup seals (2) to fail and leak brake fluid or seize up and not work at all, brake fluid on the shoes can cause the brakes to grab and lockup. The front brake system will still work, with a slightly lower brake pedal position and diminished brake operation. Once this occurs the wheel cylinder and the rear brake shoes will need to be replaced due to the brake fluid contamination.
What Will it Cost?
Typically a wheel cylinder will cost between $11.00 and $25.00 (US) each on Amazon and the shop time labor is approximately 2.0 hours. If exact labor times or procedures are needed you can ask the 2CarPros community to supply you with the information (free), or consult an online resource such as AllData DIY (pay) but this guide and video will be sufficient in most cases.
Let's Jump In!
When a wheel cylinder is being replaced it is normal for the rear brake shoes to be replaced as well. Brake shoes contain asbestos so avoid using compressed air to clean, we use water from a hose which helps contain dust partials while washing brake dust away, spray the drum and components, allow it to dry before beginning. Wear a dust mask and gloves to help eliminate harmful contaminants. In the example below the brake shoes have already been removed. This is what the wheel cylinder looks like when it is ready to be replaced.
wheel cylinder
The first step is to loosen the brake line from the wheel cylinder, using a line wrench will help you avoid rounding the brake line fitting, center the wrench on the fitting completely before applying pressure. Once loosened, brake fluid will start to drip out so have a shop towel ready.
remove brake line
Quickly use a vacuum cap to stop the brake fluid from flowing once the line is completely removed. This is necessary to stop the brake fluid from leaking so as to not empty the brake master cylinder, if this does occur the brake master will need to be bled.
vacuum cap
Use a wrench or socket to remove the wheel cylinder mounting bolts (2), in this case the bolt size is 8mm, rarely wheel cylinders are held in place by a snap ring.
remove wheel cylinder mounting bolts
Gasp the wheel cylinder firmly and remove it from the backing plate.
wheel cylinder removed
Watch the Video!
After the video please continue with the remainder of the guide to glean additional information. Complete rear brake job video.
Remove the new wheel cylinder from its box to match up to the old wheel cylinder to the new unit, they should match identically.
new wheel cylinder
Insert the wheel cylinder into the backing plate and secure it by installing the mounting bolts (hand tight).
new wheel cylinder
Use a wrench or ratchet to tighten the wheel cylinder mounting bolts. The torque setting for these particular bolts is 9 foot pounds.
tighten wheel cylinder mounting bolts
Remove the dust cap which was installed by the manufacturer to protect the fitting threads, the brake line must be straight into the wheel cylinder before the fitting will thread in. Hand thread the brake line fitting into the cylinder to prevent cross threading.
thread wheel cylinder fitting
Use a line wrench to tighten the brake line. There is no torque tightening setting for this, so a medium snug will work, do not over tighten.
tighten brake line
After the brake shoes and drum have been reinstalled use a small screwdriver to remove the bleeder cap. This job is typically performed during a rear brake job, we have broken out the wheel cylinder replacement to help simplify the repair. Before the wheel cylinder can operate correctly the brake system will need to be bled. After the job is complete, recheck the wheel cylinder for leaks.
remove bleeder cap
Questions?
If you have a car repair question, you can ask the 2CarPros community for help. We hope this guide helped you understand the repair. Please visit our 2CarPros YouTube channel for more helpful repair videos.
Repair Safety Notice: This guide is provided for general informational and educational purposes only. Vehicle repairs can involve risk of injury, property damage, or vehicle damage. Always follow proper safety procedures, use the correct tools, support the vehicle securely when raised, and consult a qualified automotive repair professional if you are unsure about any step.
