1991 Ford Taurus
JOSH RUSSELL
  • 1991 FORD TAURUS
Engine Mechanical problem
1991 Ford Taurus 6 cyl Front Wheel Drive Automatic
MY CAR WILL START AND IDEAL AND WHEN I PUT IN DRIVE AND HIT THE GAS IT DIES WHAT IS THE PROBLEM?
Monday, April 19th, 2010 AT 11:17 AM
BMRFIXIT
  • 19,053 POSTS
Check for fuel and fuel pressure
Check IAC Valve
Tuesday, April 20th, 2010 AT 9:47 PM
JOSH RUSSELL
I checked the fuel preaser and it is good. But still want go no were. But thank you alot.
Wednesday, April 21st, 2010 AT 8:55 AM
BMRFIXIT
  • 19,053 POSTS
If have distributor check ignition timing
and timing
Thursday, April 22nd, 2010 AT 5:40 AM
JOSH RUSSELL
THANK YOU ALOUT BUT COULD IT BE THE CONVERTER?AND HOW TO CHECK TIME. THANK YOU AGIAN
Friday, April 23rd, 2010 AT 11:12 AM
BMRFIXIT
  • 19,053 POSTS
Do you have a distributor?
If so try and loosen it and turn it a little left and check and then right and check
Timing: need a timing light to check
Friday, April 23rd, 2010 AT 4:58 PM
JOSH RUSSELL
Thats not it could it be converter? Well im gooning to try to take it off thank you agian. But if you think of any thang ells please let me know. Thank you agian
Sunday, April 25th, 2010 AT 10:11 AM
