1996 Ford Taurus Brake Pedal to Floor
CHRISTI992
  • 11 POSTS
I have a 96 Ford Taurus. It will not stop using the regular brakes...at all! I have to use the emergency brake. Needless to say, i don't drive it. I have had the calipers and all brake pads replaced all the way around and it still won't stop. The pedal goes all the way to the floor. No brake fluid is leaking anywhere and we bled all the brakes. It never pressures up when started. It bubbles in the reservior. What can this mean? How can it be fixed.
Aug 13, 2006 at 8:54 AM
MIKEYBDMAN
  • 623 POSTS
[quote:1b1ff110ca="christi992"]I have a 96 Ford Taurus. It will not stop using the regular brakes...at all! I have to use the emergency brake. Needless to say, i don't drive it. I have had the calipers and all brake pads replaced all the way around and it still won't stop. The pedal goes all the way to the floor. No brake fluid is leaking anywhere and we bled all the brakes. It never pressures up when started. It bubbles in the reservior. What can this mean? How can it be fixed.[/quote:1b1ff110ca]
I would say your mater cylinder is bad. However, make sure the rear brakes are adjusted correctly, and be sure you have bled all of the air completly out before replacing the master cylinder.
Aug 13, 2006 at 9:24 AM
CHRISTI992
  • 11 POSTS
I had the master cylinder changed. It works better now. Stopping more frequently, but still has some trouble every once in a while. Everything has been bled and there are no leaks. Now what?
Aug 17, 2006 at 6:27 PM
NOS
  • 320 POSTS
it still sounds like you have air in the system take it to a shop where they have a power bleeder a lot of times you can't get all the air out by pumping the breaks so by pressure bleeding them you can. (NOS) 8)
Aug 20, 2006 at 6:12 AM
Suggested Repair
After the master cylinder replacement, have the system pressure-bled with a power bleeder to remove remaining air. Also confirm the rear brakes are adjusted correctly.
Conversation Summary
A 1996 Ford Taurus would not stop with the service brakes; the pedal went to the floor, the reservoir bubbled, and there were no visible leaks after pads, calipers, and bleeding. An expert suspected a bad master cylinder and advised confirming rear adjustment and a complete bleed first. After the master cylinder was replaced, braking improved but remained intermittent, and the next advice was a shop power bleed to remove trapped air.
