Ford Taurus Brake Fluid Loss
SJMAROTTA
I drive a Ford Taurus.
The breakes almost completely stopped working.
I put break fluid in its container. It needed it.
the next day, the brakkes completely stopped working.
the brake fluid container was pretty much completely empty.
I want to fix the problem myself.
Could somebody please give my some insight as to the possible nature of the problem and what the best thing to do to fix it is.
Feb 15, 2006 at 9:34 AM
LOVESCARS
  • 359 POSTS
don't know the year but it sounds like a blown brake hose or the master cylinder went bad.
if the master is bad and your loosing fluid that quickly check the carpet up under the brake pedal it would show fluid.
to check a hose just look at the parking spot for any fluid leakage
Feb 15, 2006 at 9:37 AM
SJMAROTTA
Thank you for answering my question.
one more question
Any way that I can fix the lines or replace the M.C.
I do not have Mechanical training but I can fix things very well.
Does the system require specialized tools and/or training?
Feb 15, 2006 at 9:45 AM
LOVESCARS
  • 359 POSTS
purchase a manual on the vehicle it should give you step by step instruction. nothing worse than having to have a vehicle towed after finding you cannot handle the job in the first place.
Brakes are a safety item and repairs should be done by a certified mechanic or someone who is certain they can undertake the job.
the manuals can be purchased on this website
Feb 15, 2006 at 9:49 AM
SJMAROTTA
Thank you for your help.
StephenM
Feb 15, 2006 at 9:50 AM
Suggested Repair
Inspect for a ruptured brake hose or failed master cylinder. Check the carpet under the brake pedal for fluid and look at the parking spot for external leakage. Because brakes are a safety item, have a certified mechanic do the repair, or use a vehicle-specific manual only if you are certain you can complete the job.
Conversation Summary
A Ford Taurus owner reported brakes that nearly failed, then failed completely after adding fluid that quickly emptied from the reservoir. The expert said a blown brake hose or bad master cylinder is likely and advised checking the carpet under the pedal and the parking area for leaks. The owner asked about DIY line or master-cylinder repair; the expert recommended a repair manual and said brake work should be done by a certified mechanic or someone certain they can finish the job safely.
