1993 Ford Taurus Won't Start
Suggested Repair
While cranking, remove the vacuum line from the fuel pressure regulator and check for fuel coming out; if fuel is present, replace the regulator. Also check the coolant temperature sensor, which can cause the radiator fan to run constantly and rough running, and use an inexpensive code scanner to retrieve check-engine codes before replacing the CCRM or ECM.
Conversation Summary
A 1993 Ford Taurus with a 3.8L engine that had been sitting ran for a few days, then stalled under acceleration and would not restart. The owner confirmed spark and fuel at the rail, noted the fuel pump and radiator fan run constantly with the ignition on, and was concerned the CCRM or ECM might be at fault. The expert suggested testing the fuel pressure regulator for fuel leaking into the vacuum line, checking the coolant temperature sensor, and scanning for codes before buying expensive modules.
