1993 Ford Taurus No Start No Spark
FANTOMKYD
Hello, I have a 1993 Ford Taurus Wagon with the 3.0 V6 with 62,000 miles.
The problem first began when the car would unexpectantly shut off, often related to turning. The engine would quickly die (no sputtering) and it would lose all power, brakes would become very difficult to compress, power steering went out as well. When the car coasted to a stop I had to put it into park and re-start. The first couple times it happened re-starting was easy and had no hesitations.
Now it happened again and it will no longer start up. I have located some problems...
No spark at plugs
No power to the coil
What is before the coil? Like what computer module would control the current sent to the coil? Im confused how it was so intermitent, id associate electrical problems to pretty much work and die completely.
Thanks for any help given!!!
Fill
Oct 31, 2006 at 11:36 AM
BRUCE HUNT
  • 3,754 POSTS
You may have a cam or crank sensor that has failed.
Nov 1, 2006 at 12:09 AM
FANTOMKYD
Eeee... that sounds pretty bad, well could be worse but cranks and cams are pretty deep in the whole thing. If they have failed, would they show in a computer scan? Also, how difficult is something such as that to replace?
Thanks!
Nov 1, 2006 at 1:05 PM
BRUCE HUNT
  • 3,754 POSTS
The shafts are deep - yes but the sensors are external on the surface. Sometimes they are hard to find. But a computer scan should find it, however, you probably would need to take it to the shop for the scan. OBD or OBDI vs. OBD2. OBD2 is easy and every owner of a car 1996 and newer should own a service manual and scanner. Cost of these items together is $50. You have a car that is prior to OBD2 (On Board Diagnostics) and getting the code would probably require the shop to read.
Nov 1, 2006 at 11:28 PM
Suggested Repair
Have the camshaft and crankshaft position sensors checked. They are external sensors, not deep in the engine, and a failed sensor can cause intermittent stalling and no spark or coil power. Because this is a pre-OBD2 vehicle, a shop scan is likely needed to read codes.
Conversation Summary
A 1993 Ford Taurus 3.0 V6 wagon began stalling suddenly, often while turning, then would not restart. The owner found no spark at the plugs and no power to the coil and asked what controls the coil. The expert suggested a failed cam or crank sensor, noted that the sensors are external, and said a shop scan would likely be required because the car predates OBD2.
