1993 Ford Taurus Won't Start
TAYLOR_AMO216
I have a 1993 Ford taurus GL 3.0 FLex V6. It has over 100,000 miles on it but works farily good. Just recently my car has not been starting all of the time. It has happened about 5 times. When I try to start my car it will not turn over. The radio and lights work though. My girlfriends dad told me to tap the solenoid and it will work. That worked a couple times, and just leaving the car worked sometimes too. Is there any way to repair this? How much to replace? Anyway to prolong the life? Thank you a lot.
May 24, 2007 at 3:45 PM
RUDPRO
  • 224 POSTS
Make sure it is the solenoid and not something else. Get a voltmeter. Next time it won't start check the small wire that goes to the middle, small terminal of the solenoid. I believe it has a rubber boot over it and the wire is red with a light blue stripe. Take the wire off and hook up the voltmeter positive to the wire and the black wire to ground. Have someone turn the key to start position. You should get 12 volts dc. Do this test when the car doesn't want to start though. Also, you may have bad or dirty connections on the battery, starter solenoid and starter. Check and clean all of these connections. Also, disconnect the solenoid from where its mounted and check and clean that too. That's where it gets it's ground from. A new solenoid is about $35, and not hard to change. If you change it, make sure you get the wires put back on correctly.
May 24, 2007 at 6:04 PM
Suggested Repair
When it fails to crank, test the small solenoid start wire (red with a light blue stripe) for 12 volts with the key in start. Clean the battery, solenoid, starter, and solenoid mounting ground connections. A replacement solenoid is about $35 and is not hard to install if the wires are reconnected correctly.
Conversation Summary
A 1993 Ford Taurus GL 3.0 sometimes will not crank, though the radio and lights still work. Tapping the solenoid or waiting has occasionally allowed it to start. The expert advised confirming the solenoid with a voltmeter test on the small start wire, cleaning battery, solenoid, and starter connections including the solenoid ground, and replacing the solenoid if needed for about $35.
