1994 Ford Taurus Engine Shake After Start
JAKIN
  • 16 POSTS
I have a 94 Ford Taurus with 140,000 miles. The last couple of days right after I start the car, it feels like the engine is shaking. Yesterday it only did it for about a minute while I let it idle before I started driving, but today it did while at idle, then I felt it periodically as I drove to work, about 5 miles. Just wondering what it might be. I am sorry if this seems vague. The only thing I thought of is motor mounts? Any help would be greatly appreciated. Thanks in advance!
Jul 1, 2006 at 1:46 AM
TAURUSWHEEL
  • 718 POSTS
What size engine??? 3.0 or 3.8 ?? Motor mounts will usually not cause shaking, to check for a broken mount either put it in park, hold the brake pedal and slightly rev the engine, there will be a definite thump if there's a problem... or better yet have someone observe the engine, make sure not standing in front of the vehicle, while you do the same park, brake rev deal.. the engine will lift up pretty good with a bad mount... if you have the 3.8, I wouldn't wish that motor on anyone, they are notorious for busting motor mounts,, weak design combined with big torque,, and the worst thing is, no one has improved the mount to where it's reliable in the long haul.. you live in an area where snow and ice are common, you spin your wheels even a little bit, then grab a piece of dry pavement you're looking at a broken mount,, I want to say the right front is mostly the culprit, not 100% on that though
Jul 2, 2006 at 5:57 AM
JAKIN
  • 16 POSTS
I have the 3.0 so at least that makes me feel a little better from what you said about the 3.8. Thanks for the tip on how to test for a bad mount. If it is not the mounts do you have any other suggestions?
Jul 2, 2006 at 8:26 AM
TAURUSWHEEL
  • 718 POSTS
I'd throw open the hood and check all wiring, vacuum lines, etc make sure nothing has been knocked loose,, any work done on it lately??? Check the sparkplug wires, make sure they're tight.. Might be time for a tune-up, new plugs and wires,, also important take your distributor cap off, I would almost guarantee there's corrosion inside on the rotor tip and the contacts on the cap itself,, replace the cap and rotor with new if not done recently,, make sure you get a little tube of dielectric grease to lightly coat the rotor and cap contacts, you need the grease for the sparkplug tips and wire boots anyway, then regularly check the cap and rotor for buildup.. also as usual I recommend you get yourself a code reader for your car, around 30 bucks, and learn how to use it, not hard.. could be throwing a code and not setting the check engine light..
Jul 2, 2006 at 10:19 AM
JAKIN
  • 16 POSTS
Thank you for the good advice. I plan on changing the air and fuel filter as well as check the wires and plugs and distributor cap and rotor. Do you know or know where I can find out the proper spacing for the plugs on a 94 taurus? Thanks again for the advice!
Jul 3, 2006 at 5:12 AM
JAKIN
  • 16 POSTS
Also, I was wondering what brand of spark plugs you would reccomend? What are the differences of the cheap/expensive ones? Thanks for any help.
Jul 3, 2006 at 5:25 AM
TAURUSWHEEL
  • 718 POSTS
Gap for plugs should be on the radiator sight shield, that label would also include the vacuum routing diagram,, I think it's 052-056.. I would use either Motorcraft which is oem or Autolites also have worked fine for me... are you familiar with doing the fuel filter???
Jul 3, 2006 at 11:58 AM
JAKIN
  • 16 POSTS
Thanks. To be honest, I have never changed the fuel filter myself. I know it is easy, and I have read a few places about how to do it. I would appreciate any suggestions/tips you may have to offer though.
Jul 4, 2006 at 4:59 PM
Suggested Repair
Test motor mounts by holding the brake in Park and slightly revving while watching for a thump or excessive engine lift. Inspect vacuum lines, wiring, and spark-plug wires. Perform a tune-up with Motorcraft or Autolite plugs gapped to 0.052-0.056 inch, new wires, and a distributor cap and rotor lightly coated with dielectric grease. Scan for stored codes even if the check-engine light is off.
Conversation Summary
A 1994 Ford Taurus 3.0 with 140,000 miles shakes briefly after starting and sometimes while driving. The expert said mounts are less likely on the 3.0 than the 3.8 and described a safe rev test. Further suggestions were loose vacuum lines or wiring, a tune-up including plugs, wires, cap and rotor with dielectric grease, and a code reader. Plug gap was given as about 0.052-0.056, with Motorcraft or Autolite recommended. The owner planned air and fuel filter service but no fuel-filter procedure was provided.
