My 1994 SHO 3.2 with a new motor in it as of 1-2006, 157 is the miles on car, has been starting ruff after I have driven it for about 4 to 10 miles, the check engine lite will come on and the RPM gage will stop working around the fifth mile of driving. When that happens I can't get it started unless I hold my gas pedal to the floor, turn the key on and wait until all of the lites go out before starting. When doing that about half of time it starts ok and the other half of the time it starts ruff. When it is cold it will start just fine. I have had 4 shops try to pull the codes but nothing is recording. (running and not running) I have jumped the self test input with the singal return, and tried to read the lite as it flashes.I realy want to know where to start. FYI here are all of the codes that I could get from the part store, only one that came up: 212 Loss of ignition diagnostic monito input to spark output circuit grounded and 214 Cylinder identification circuit failure and 332 EGR flow insufficient. please let me know if you can help
Sep 15, 2006 at 5:27 AM
