1993 Ford Taurus Won't Start
FORDBOY24
car will not start have change icm, pick up mod, ecv but cant find ecm can you tell where it is
Mar 25, 2006 at 2:32 AM
LOVESCARS
  • 359 POSTS
usually under the plastic shield on top of the radiator or one the passnger side kick panel
Mar 25, 2006 at 1:13 PM
LOVESCARS
  • 359 POSTS
The ignition control module should be located on the side of the distributer if so equipped
Mar 25, 2006 at 1:14 PM
Suggested Repair
Look for the ECM under the plastic shield on top of the radiator or in the passenger-side kick panel. If the vehicle is equipped with a distributor, the ignition control module is on the side of the distributor.
Conversation Summary
The owner of a 1993 Ford Taurus wagon says it will not start after replacing the ICM, pickup module, and ECV, and asks where the ECM is located. The expert says the ECM is usually under the plastic shield on top of the radiator or in the passenger-side kick panel, and notes that the ignition control module is on the side of the distributor if equipped.
