1990 Ford Taurus No Spark No Start
DANSOLO
I am working on a 90 Taurus for a friend. 70,000 miles with a 4cyl engine. The engine cranks over just fine, but it won't start. My limited knowledge on a Taurus is the fuel pump in the gas tank, which in this case I do not think is the problem. The ignition module which I replaced, did not help. I checked the coil...There is no spark coming out of it to the plugs, There is power from the battery to the coil however. I replaced the coil and still have the same problem. Does anyone know what else I should be checking? Thanks.
Aug 4, 2007 at 11:43 AM
  • 75,988 POSTS
[quote:2c4b80137d="dansolo"]I am working on a 90 Taurus for a friend. 70,000 miles with a 4cyl engine. The engine cranks over just fine, but it won't start. My limited knowledge on a Taurus is the fuel pump in the gas tank, which in this case I do not think is the problem. The ignition module which I replaced, did not help. I checked the coil...There is no spark coming out of it to the plugs, There is power from the battery to the coil however. I replaced the coil and still have the same problem. Does anyone know what else I should be checking? Thanks.[/quote:2c4b80137d]
Did you check the conditions of the cap and rotor, if that rotor tip is too far from the tower contact inside spark w/n make it to the plugs.
Stick a test light at the neg. side of the coil while cranking it is it blinking? if not could be the distributor pick-up or CPS.
What did the coil has to say when you check it-meaning resistances.
Find the schraeder valve on the fuel rail-press it -do you see fuel.
Aug 4, 2007 at 7:18 PM
Suggested Repair
Check the distributor cap and rotor gap, then use a test light on the coil negative terminal while cranking. If it does not blink, test the distributor pickup or crankshaft position sensor. Also verify coil resistance and press the fuel-rail Schrader valve to confirm fuel delivery.
Conversation Summary
A 1990 Ford Taurus with a 4-cylinder engine cranks but will not start and has no spark at the plugs. The ignition module and coil were already replaced, and battery power reaches the coil. The expert recommends checking the cap and rotor, the coil negative signal while cranking, the distributor pickup or crankshaft position sensor, coil resistance, and fuel at the rail Schrader valve.
