1990 Ford Taurus Car Not Starting
KENE374
  • 1990 FORD TAURUS
  • 6 CYL
  • FWD
  • 10,000 MILES
Car will crank but not fire up. Replaced timing chain, replaced ignition module, fuel pressure 50 lbs, plugs cleaned and gapped, wires good, cap and rotor useable, scan told me code 67, (PNP or clutch switch circuit failure).
Saturday, January 17th, 2009 AT 12:49 PM
JGAROFALO
  • 489 POSTS
Start with the basics. Check for spark. For this, you can use an inline spark tester. Observe for spark during cranking. Also, check for fuel pressure. There is a test port on the fuel rail. You can attach a gauge there to check for fuel pressure.
You need THREE basic things for the engine to run:
1) Fuel and air mixture
2) Spark - at the correct time
3) compression
One of these 3 things is missing.
Let me know which one is missing, and I can give you some more help on diagnosis.
Hope I have been of some help.
Wednesday, January 21st, 2009 AT 4:15 PM
BMRFIXIT
  • 19,053 POSTS
Check injector pulse
check firing order
do a compression test
check for spark
check TPS volts
when key on do u have check engine light on (you should )if not check eec relay
Wednesday, January 21st, 2009 AT 6:39 PM
