1998 Ford Taurus No Start Dim Spark
JEFFKAL
I have a 1998 Ford Taurus V6 3.0 SE OHV with 83,000 miles
I have spark on all cylinders and fuel on the plugs so I know I'm getting fuel and gas to the cylinder. i also checked the cam position sensor and it pulse like it said in the book also checked the crank positioning sensor and it looks like it working properly also I did not get a scan tool yet I have it on order so I should have by next week but what else should I look at it?
when I turn it over a few time I her a cylinder fire(don't know which one) and that's it! it doest even want to try to start
Thanks for your help
Jeff
Jun 4, 2007 at 4:18 AM
2CARPRO JACK
  • 11,533 POSTS
Is the spark bright blue or dim orange? Does the engine sound funny when turning over? or does it turn over smoothly
Jun 4, 2007 at 4:38 AM
JEFFKAL
Dim orange and it turns over smoothly.
I was on the way home on the interstate and it just died. I had it towed to my house. I'm just puzzled
Thanks Jeff
Jun 4, 2007 at 9:45 AM
2CARPRO JACK
  • 11,533 POSTS
Try a coil. Spark should be bright blue and jump at least a 1/2 inch
Jun 5, 2007 at 12:46 AM
JEFFKAL
I will check the packs!!! But I want to check the timming how would I go about it ?
Jun 5, 2007 at 1:08 AM
2CARPRO JACK
  • 11,533 POSTS
If it has a coil pack, the timing isnt adjustable, computer does it
Jun 5, 2007 at 1:24 AM
KIMO
I have a 1989 ford thunderbird super charge. 5 speed manual tran, I had a new motor out of the crate from ford installed it was running but not right so sent it to a garage now it wont start at all, it is getting gas and spark , what do you think could be the problem
Jun 5, 2007 at 9:03 AM
JEFFKAL
[quote:149a116b70="2CarPro Jack"]If it has a coil pack, the timing isnt adjustable, computer does it[/quote:149a116b70]
i just trying to make sure it's not the timing chain
Jun 5, 2007 at 9:27 AM
Suggested Repair
Test or replace the ignition coil or coil pack. Spark should be bright blue and jump at least 1/2 inch. On this coil-pack engine, ignition timing is computer-controlled and not adjustable.
Conversation Summary
A 1998 Ford Taurus 3.0 OHV died on the interstate and will not restart. The owner reports fuel at the plugs, a pulsing cam sensor, and a crank sensor that appears to work, but spark is dim orange and only an occasional cylinder fires. The expert advised checking the coil because spark should be bright blue and jump at least 1/2 inch, and said timing is not adjustable when a coil pack is used.
