Illuminated check engine light?
BIGCHIEFNC
Well the mechanic said he did that after he fixed it. Told me to drive it for a while so the system can be completly ready for inspection.I did and the next day the engine comes on
Saturday, October 24th, 2020 AT 11:32 AM (Merged)
LEGITIMATE007
  • 5,121 POSTS
Read it again, and lets see whats the problem now
LUVDOC
  • 2005 FORD TAURUS
Engine problem
2005 Ford Taurus 6 cyl Wheel Drive Type unknown Automatic 49,000 miles
my engine lght just came on, what could it be? Is it serious?
FLEXY5
  • 512 POSTS
You need to have it scanned and post the codes back on here. There are only 1400 codes that Ford uses and some of them can be serious.
COUNTRYMUMMA2
  • 2005 FORD TAURUS
Gas gage needle flickers and check engine light is on but registers no code? Can it be the computer
  • 109,885 POSTS
If the light is on, there should be a code. Have you checked all connections between the scanner port and the PCM?
COUNTRYMUMMA2
Yup its not showing anything
  • 109,885 POSTS
Okay. This isn't going to be an easy one. Since there is an indication that the fuel system may be having issues, I want you to check fuel pump pressure. There is a change that fuel pressure is dropping, the computer is recognizing it, but not setting a code.
