HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Ranger
Engine
Symptoms
Compression
Low Compression?
PREV
1
2
NEXT
RUDPRO
MECHANIC
I noticed your other post about the oil spraying all over the engine. I would do a compression test. You should have 101psi minimum for that engine.
Wednesday, July 29th, 2020 AT 10:48 AM (Merged)
DUSTIN2551
MEMBER
What should I do if it isn't that psi?
RUDPRO
MECHANIC
That would mean you need a valve job, lifters and maybe a new camshaft. Upper engine rebuild.
RUDPRO
MECHANIC
Sorry, left some items out. It could be just the head gaskets. It could also be the piston rings and/or the pistons, cylinder walls.
PREV
1
2
NEXT
Please
login
or
register
to post a reply.
Related Engine Compression Content
The Engine Cut Out While Driving And The Won't...
The Engine Cut Out While Driving And The Won't Start. The 1st Time It Happened After 10 Minutes It Started. 2 Months Later It Would Not...
Asked by
Daytona#187
1 ANSWER
2006
FORD RANGER
VIDEO
Engine Compression Test
Instructional repair video
GUIDE
Compression Test
A compression test is a valuable diagnostic procedure that helps determine the health of an engine by measuring the pressure generated in each cylinder. The following is a...
Engine Misfire?
My Truck Hesitates When Starting Then Has A Lobe When Idling Replaced Plugs Wires With Autolite And Wires From Autozone Crankshaft Sensor...
Asked by
stoph8n29
5 IMAGES
2006
FORD RANGER
2006 Ford Ranger Engine Dies
Hi I Have A 06 Ford Ranger Shortbed Regular Cab, And Engine Runs Great, But Everynow And Then It Just Dies. Sometimes It Can Start Back Up...
Asked by
johnv427
2006
FORD RANGER
2006 Ford Ranger Trouble Starting
Twice In The Last Month I Have Had Trouble Where My Truck Will Not Start. When I Turn The Ignition, The Engine Turns Over But Will Not...
Asked by
dsims66
1 ANSWER
2006
FORD RANGER
2006 Ford Ranger To Lean On Both Banks
It Started With A Random Misfire And Misfire Within 100 Revolutions And Misfire Number 4 Cyl. Dealership Said Possible Intake Gasket Leak...
Asked by
stoph8n29
1 ANSWER
2006
FORD RANGER
VIEW MORE
Low Compression Symptoms
Low Compression Causes
