2006 Ford Ranger to lean on both banks
106,000 MILES • 6 CYL • 2WD • AUTOMATIC
STOPH8N29
it started with a random misfire and misfire within 100 revolutions and misfire number 4 cyl. dealership said possible intake gasket leak turned out #4 injector was bad ran fine for awhile now it says to lean of both banks went over intake and vaccum with wd40 engine never revved up after it idles for about 5-10 minutes check engine light flashes
Jan 26, 2010 at 3:54 AM
  • 110,246 POSTS
It does sound like a vacuum leak. Have you checked all of the vacuum hoses and the base gasket on the throttle body? Also, I never heard of using WD40 to check for a leak. Most people use starting fluid. However, it can catch fire if you hit the wrong place. If you try that, keep a fire extinguisher near by.
Let me know what you find.
Feb 2, 2010 at 1:36 PM
