Ford Overfilled Oil Level
FORD
JONS89PGT
  • 8 POSTS
Went to JiffyLube to get oil changed and I noticed they overfilled the crankcase.
I've heard thats not good for the engine...
The oil is a good half inch above the full line
thanks
Mar 16, 2007 at 6:58 AM
  • 31,937 POSTS
Hi there,
That should not be to much of a problem, but you should go back and get it drained to the correct level, after all you payed for a service and they should make it right!
Mark (mhpautos)
Mar 17, 2007 at 1:49 AM
Suggested Repair
Return to the shop and have the excess oil drained so the crankcase is at the correct full level.
Conversation Summary
The owner noticed the crankcase was overfilled by about half an inch above the full mark after an oil change and asked whether that could harm the engine. The expert said it should not be a major problem but recommended returning to the shop to have the oil drained to the correct level.
