2002 Ford Explorer Ran Without Oil
DMAKOCH
I took my 2002 Ford explorer to the Ford Dealer that I bought the truck from and had the oil changed. When I dorve away thew truck killed right after I left the dealer. It killed again two block away. I went back to the deraler and he came with me to the car and found that he had to add 6 quarts of oil. They had drained the engine buut did not put any oil inot the engine. He filled the engine with oil and then drove the truck and said everything would be OK because there are sensors in the engine to stp it before it causes any damage. Ist that true? What should I do?
Apr 16, 2007 at 3:50 AM
MERLIN2021
  • 17,250 POSTS
That's perfect world scenario! It's true they have sensors to dissable the truck but it should not have started! if you drove a block, get a guarantee from the owner of the dealership that they will replace the engine if it needs one! And have them admit in writing that they forgot the oil!
Apr 16, 2007 at 8:31 PM
Suggested Repair
Get a written admission from the dealership that the oil was not refilled, and a written guarantee from the dealership owner to replace the engine if it is damaged.
Conversation Summary
The owner of a 2002 Ford Explorer had the oil drained during a dealer oil change but not refilled. The Explorer stalled shortly after leaving, and the dealer later added six quarts of oil, claiming engine sensors would prevent damage. The expert says sensors may disable the engine but it should not have started, and advises obtaining a written admission and an engine-replacement guarantee from the dealership owner.
