1994 Ford Explorer High Oil Level
XPLOR94
I have a 94 explorer 4x4 110,xxx miles.
lately I have had to change the oil every 2 month because the oil level is about 3inches higher than normal. when it get like this it shakes bad. but the truck does not overheat. after last oil change I left the oil pan screw slightly loose to allow leakage.I checked to see if there was antifreeze mix with the oil and everything was fine. please help me.
Aug 15, 2006 at 4:40 PM
NOS
  • 320 POSTS
does the oil smell real rich with gas and thin if so check you fuel pressure regulator pull the red line off it and see if there are signs of gas if so replace it but don't rule it out can be bad and pumping gas into your crank case.(NOS)
Aug 20, 2006 at 7:40 AM
Suggested Repair
Check whether the oil smells strongly of gasoline and feels thin. Disconnect the fuel pressure regulator vacuum line (described as the red line) and look for fuel. If fuel is present, replace the regulator, which may be leaking gasoline into the crankcase.
Conversation Summary
The owner of a 1994 Ford Explorer reports the oil level rising about 3 inches above normal every couple of months, causing shaking, without overheating or coolant mixed into the oil. The expert suggests gasoline may be diluting the oil and recommends checking the fuel pressure regulator vacuum line for fuel and replacing the regulator if fuel is found.
