2002 Ford Explorer oil change
150,000 MILES • 4 CYL • 4WD • AUTOMATIC
GDISS
AFTER YOU CHANGE THE OIL, HOW DO YOU RESET THE CHANGE OIL WARNING?
Feb 18, 2010 at 10:57 PM
LEGITIMATE007
  • 5,121 POSTS
YOU CAN BRING IT TO AUTOZONE, AND THEY WILL DO IT FOR FREE, OR YOU CAN JUST LET IT GO THROUGH ITS DRIVE CYCLE/RELEARN CYCLE AND IT WILL GO OFF BY ITSELF
Feb 19, 2010 at 3:56 AM
LEGITIMATE007
  • 5,121 POSTS
1: Press the trip reset button to access the System Check function.
2: press and release the button again to display Oil Life XX%.
3: Press and hold the button for 2 seconds to display "If New Oil Hold Reset".
4: Release and hold button again untill display says "Oil Life Set To 100%"
Feb 19, 2010 at 3:59 AM
