2006 Ford Explorer Oil Changed Required Msg
53,000 MILES • 6 CYL • 4WD • AUTOMATIC
JAYATCH
I change my own oil, and am able to reset the oil life back to the 100%, however the oil change required msg still apears on the msg center. How do I reset this?.
Sep 12, 2008 at 8:03 AM
MERLIN2021
  • 17,250 POSTS
I found that oil change reset procedure wasnt that clear, and that the driver info/message center in the instrument cluster had different wording. to reset- press trip/reset button on the i/p cluster, " goto setup menu hold reset" will appear. then hold trip/reset button and release. then it will display " system check hold reset"- press and hold trip reset, dont release- will display- "hold reset if new oil", then release. turn ignition off for approx 5 secs- turn ignition back on to verify reset with no messages.
Sep 12, 2008 at 8:10 AM
